15 years agoPlease advise: Unable to create project in Eclipse NIOSII Software
file:///C:/Users/CHOOIL%7E1/AppData/Local/Temp/moz-screenshot-5.png file:///C:/Users/CHOOIL%7E1/AppData/Local/Temp/moz-screenshot-6.png Hi, I hope to have your advise on this. I am working out ...
15 years ago --- Quote Start --- May i know what i the root of this problem? Why i have to run my NiosII Eclipse as administrator? --- Quote End --- I am not 100% sure, but I think the problem is simply that the permissions are not set correctly by the installer for all the required executable files. You could probably fix this by changing the permissions manually but it is easier to just run as administrator. This problem seems to have been fixed in Quartus 10.1. --- Quote Start --- And can i ask for your advise how can i do a program with NIOSII to record the sound from Microphone and then save the sampled sound data into memory? And how can i retrieve the data from memory for Fast Fourier Analysis? --- Quote End --- I would suggest starting a new thread about this.
