21 years ago
PIO Vs. Avalon ?!
hi....i&#39;m using a niosII processor and I wanna add a hardware block external to the processor and on the same FPGA that performs a general function (eg, Vector dot product). Should I interface it to the processor using the avalon bus or can i interface to a PIO block that&#39;s already interfaced to the avalon bus? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
thnx
    Hi wesam,
    I started a design using a PIO for address, a PIO for control, and a PIO for
    data. I quickly changed my mind once I started writing the device driver
    code -- it was much more time-efficient (and MIPS efficient) to just write a
    simple avalon interface. Later, I decided I needed DMA support ... and it
    basically came "for free" since I already had the avalon interface.
    In general, if you&#39;re doing more than just twiddling a few bits, you should
    consider the avalon interface. One way or another, you&#39;ll end up writing the
    interface logic anyway-- whether it&#39;s in an HDL or in C ... but the HDL
    strategy comes with some built-in "freebies" ;-)
    --Scott
    thnx a lot,
    so, are the &#39;Create New Component&#39; and the &#39;Interface to User Logic&#39; in SOPC implement an avalon interfaced device or just any general device?
    thnx
    The interface to user logic will create the avalon interface for your logic.
    You&#39;ll have to select address width, data bus width, etc. as appropriate.
    --Scott
    I should be more clear ... sorry:
    The interface to user logic will export the avalon bus signals from the
    system module that your custom logic connects to.
    --Scott
