16 years agoPIO or Custom Component?
I'm starting a design with the SOPC (NIOS) and I cant decide if I should put my signal processing functionality outside the SOPC (and use the PIO) OR create a custom component and put it in the SOPC....
16 years agoI would go with a custom interface because...
a- it is not that difficult to implement b- you have more flexibility as far as address map (or number of addressable IO) c- you can implement bursting if you need to - I am not sure PIO can handle that d- you can tell when the CPU is reading and writing without having to use interrupts or polling hope this helps.
