16 years agoPIO LEDs always on
Hello, i have a NiosII sopc with a PIO[24] called LED. It is connected to the LEDs on the DE3 board. now i have a simple application : # define LED_BASE 0x00041010 // this is the base i...
16 years agoIn sopc builder have you defined this pio as output only or bidir? If the latter, you need to set the direction bits for outputs.
Check also in Quartus project if all connections are ok and signals are assigned to right pins. Regarding your question about pointers, using char is not mandatory. Infact you can use int when your pio is up to 32bits wide. Probably all samples use char because this is the native addressing mode of processor. Cris
