16 years agoPIO Interrupts and MicroC - OSStart() etc.
I had a to make a change from an approach based on an FPGA change from timer interrupts (TIMER_CONTROL) - which worked - to edge captured PIO interrupts. So consider the pseudo code
int const WAIT_FOREVER = 0 ;
INT8U err = 0;
void ISR20Hz ( void* context, alt_u32 id )
IOWR_ALTERA_AVALON_PIO_EDGE_CAP( PRIMARY_INT_BASE, 0x0 );
//if ( !OSRunning ) {
// OSStart(); // start multitasking undeer uC/OS-II
if ( OSRunning )
err = OSSemPost ( TwentyHz_Sema ) ;
if ( err != OS_NO_ERR )
std::cout << "e" ;
void Run20HzTask ( void* context )
while ( 1 ) {
OSSemPend ( TwentyHz_Sema, WAIT_FOREVER, &err ) ;
if ( err != OS_NO_ERR ) {
std::cout << "." ;
continue ;
std::cout << "." ;
// work
int main()
std::cout << "1" ;
IOWR_ALTERA_AVALON_PIO_IRQ_MASK( PRIMARY_INT_BASE, 0x0 );
// Reset the edge capture register. */
IOWR_ALTERA_AVALON_PIO_EDGE_CAP( PRIMARY_INT_BASE, 0x0);
std::cout << "2" ;
| here I:
| a) Setup the TwentyHz_Sema semaphore with OSSemCreate
| b) Setup OSTaskCreateExt with the Run20HzTask
// later - start the interrupt
IOWR_ALTERA_AVALON_PIO_IRQ_MASK( PRIMARY_INT_BASE, 0x1 );
std::cout << "3" ;
//The alt_irq_register() function returns zero if successful, or non-zero otherwise.
int const ret_val = alt_irq_register ( PRIMARY_INT_IRQ,
0, ISR20Hz );
if ( ret_val != 0 )
return EXIT_FAILURE ;
OSStart();
At issue: a) OSStart within main never executes. As a result OSRunning is never set to True for the semaphore to post. b) If I comment out OSStart within main() and instead call OSStart once within the ISR20Hz function. i.e.
if ( !OSRunning ) {
OSStart(); // start multitasking under uC/OS-II
Semaphores are/appear to be posted but the task that pends on the semaphore doesn't execute. c) Once this line is executed
I no longer see stream outputs. The question: Any ideas on what I'm doing wrong here? Thanks in advance.No RepliesBe the first to reply
