22 years agoPIO INTERRUPT
i configed the pio_1 of my nios II as synchronously capture,either edge,interrupt generated by edge. before i call the isr,i enable the irq of pio_1 by write the code as bellow: void* edge_cap...
22 years agohi all
I do capture the edge ,so it seems that we can connect the interrupt singal from inside the fpga. then why i find that the code inside isr (pio_interrupt handle) was not executed? the first argument in alt_irq_register() is PIO_1_IRQ,and the third argument is the isr (pio_interrupt handle); I can find any mistake in my code. BTW,my nios II only has tow periphery.:pio_0 and pio_1; and the on chip memory is 8kx32bits. does the nios II isr need large memory space? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
