20 years ago
pio drive
hi all,
does any one have a project(C code) which enable to drive PIO of 1s40 board (sevenseg, lcd, led pio)
I used the count_binary example of altera, in nios II IDE it works very well.
but when I create a nios2 linux project it won't compile
I think I have problems with Makefile
please help me
    there is the problem I got : http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
    make -k all
      no emulation specific options.
    make: *** No rule to make target `alt_irq.h&#39;, needed by `count_binary.o&#39;.
    make: *** No rule to make target `io.h&#39;, needed by `count_binary.o&#39;.
    make: *** No rule to make target `alt_types.h&#39;, needed by `count_binary.o&#39;.
    make: *** No rule to make target `altera_avalon_pio_regs.h&#39;, needed by `count_binary.o&#39;.
    make: *** No rule to make target `nios2.h&#39;, needed by `count_binary.o&#39;.
    make: *** No rule to make target `system.h&#39;, needed by `count_binary.o&#39;.
    make: Target `all&#39; not remade because of errors
    Hi sdhnain,
    --- Quote Start ---
    originally posted by sdhnain@May 9 2006, 05:03 PM
    there is the problem i got : http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif
    make -k all
    make: *** no rule to make target `alt_irq.h&#39;, needed by `count_binary.o&#39;.
    make: *** no rule to make target `io.h&#39;, needed by `count_binary.o&#39;.
    make: *** no rule to make target `alt_types.h&#39;, needed by `count_binary.o&#39;.
    make: *** no rule to make target `altera_avalon_pio_regs.h&#39;, needed by `count_binary.o&#39;.
    make: *** no rule to make target `nios2.h&#39;, needed by `count_binary.o&#39;.
    make: *** no rule to make target `system.h&#39;, needed by `count_binary.o&#39;.
    make: target `all&#39; not remade because of errors
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15229)</div>
    --- Quote End ---
    Please post your Makefile.
    --- Quote Start ---
    originally posted by sdhnain@May 9 2006, 10:51 PM
    hi all,
    does any one have a project(c code) which enable to drive pio of 1s40 board (sevenseg, lcd, led pio)
    i used the count_binary example of altera, in nios ii ide it works very well.
    but when i create a nios2 linux project it won&#39;t compile
    i think i have problems with makefile
    please help me
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15227)
    --- quote end ---
    --- Quote End ---
    You can&#39;t use HAL api in uClinux.
    Look at the sample pio driver in arch/nios2nommu/kernel/pio.c
    thanks hippo,
    the pio.c is good, but it drives only LEDs and seven seg, I need also LCD.
    is it possible ?
    --- Quote Start ---
    originally posted by sdhnain@May 10 2006, 04:52 PM
    thanks hippo,
    the pio.c is good, but it drives only leds and seven seg, i need also lcd.
    is it possible ?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15250)
    --- quote end ---
    --- Quote End ---
    There is no LCD driver for nios2 dev board.
    You will have to write or port one.
    --- Quote Start ---
    originally posted by hippo+may 10 2006, 05:28 am--><div class='quotetop'>quote (hippo @ may 10 2006, 05:28 am)</div>
    --- quote start ---
    <!--quotebegin-sdhnain@May 10 2006, 04:52 PM
    thanks hippo,
    is it possible ?
    --- quote end ---
    --- Quote End ---
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15252)</div>
    [/b]
    --- Quote End ---
    Hippo,
    Is there any pointer to what should look at to write a LCd application for NIOS ii uclinux ?
    hi all, i&#39;m also trying to control the lcd module using c program. pls guide. thx.
