21 years agoPIO devices under uClinux
I'm having a problem getting the PIO ports to work under uClinux. If I try to access the PIO by reading or writing to the memory location, pointed to by the pio struct, then nothing seems t...
21 years agoI got it working!!!
The problem was entirely mine and present in my code. I apologize for any time that was wasted. Just for anyone else's benefit, the simplest method that worked for me was just to declare a pointer of type np_pio. I then used the variables within the structure to address the peripheral directly. It works great. I DID NOT have to remove DCACHE either, so the MSB of the address being set truly does bypass the cache. The error in my code was the use of a "<" instead of a "<<" to perform a bit-shift operation. I have done this thousands of times, but it was a simple typo. Thanks for your help.
