21 years agoPins missing in reference design?
I'm working on a design that is basically identical to the design used by the 1c20 reference card. I'm having problems with both the CF and the Ethernet. I guess my main problem is...
21 years agoPretty much all the Ethernet pins are routed on the PCB but not all of them are used by the lan91c111 controller in SOPC Builder. If you want to see that device working try out a hardware reference design like standard or full-featured and use the webserver software template.
