20 years agoPin Assignments on the Nios II Eval Board
Hi, I ordered a Nios II Eval Kit from Altera recently, it looks like this: http://www.altera.com/products/devkits/images/n2eval_cyc_sml.jpg http://www.altera.com/products/devkits/alt..._ev...
20 years agoSean,
perhaps it helps when you import the pin assignments from the original development board design. In e.g. <NIOSDIR>\examples\verilog\niosII_cyclone_1c20\full_featured\ you'll find a .qsf file which contains all the pin assignments as 'set_location_assignment PIN_XX ...'. You can copy these lines into your own .qsf file and then label your pins to PROTO1_IO[] or PROTO2_IO[]
