20 years agoPin Assignments on the Nios II Eval Board
Hi, I ordered a Nios II Eval Kit from Altera recently, it looks like this: http://www.altera.com/products/devkits/images/n2eval_cyc_sml.jpg http://www.altera.com/products/devkits/alt..._ev...
20 years ago --- Quote Start --- originally posted by begleysm@Mar 19 2006, 05:38 PM hi,
i ordered a nios ii eval kit from altera recently, it looks like this:
http://www.altera.com/products/devkits/alt..._eval_1c12.html (http://www.altera.com/products/devkits/altera/kit-nios_eval_1c12.html)
i am wanting to drive an lcd using 11 of the user definable pins set to output mode. i've made a project, i have a built a system in the sopc builder based off of an altera tutorial that has a nios ii soft processor code, jtag uart, a pio core, and few other objects. in quartus ii i've got my sopc system on a block diagram with input and ouput pins attached. my problem is related to the pin assignment. i can see where i can assign pints to pin_g3, or pin_a5, etc. but, as hard as i've tried, i cant find anything, anywhere, that tells me what pin name (pin_g3, etc) is associated with which physical pin on the device (ie: the prototyping area on the right hand side of the picture).
thanks in advance,
sean
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13589)
--- quote end ---
--- Quote End --- The traditional way of doing this is to open/print out the board schematic. You should be able to trace the desired user I/O pin back to the FPGA "symbol" in the schematic and note the corresponding FPGA pin, e.g. "A5", which you'd then assign in Quartus, e.g. "Pin_A5". Quite frankly, this is an okay process if you just have a few pins, but it is error prone and I'd recomend printing out the schematic and going over it with a highlighter to avoid mistakes. Troubleshooting a mis-assigned pin is no fun, so double-check as you go. A relatively new feature in SOPC Builder gets past this - the board component/description editor, which reads a board netlist and then correlates peripheral I/O on the board with FPGA pins automatically; make the computer do the error-pront work. This is provided for most Altera dev boards, pre-configured.. but, sadly, it has not been provided for the 1C12 eval board (sorry!).
