20 years agoPerformance Issues
I am in the process of debugging a custom Nios II system. I have implemented a NIOS II/f CPU with and EPCS controller. I have created a custom component to access a SRAM in which my firmware is runni...
20 years agoThank you everyone for all your information.
MSchmitt, when you stated :- "nowadays the readdata is a wire with a set of combinatorical logic and now each access is only 1 clock cycle long, regardless of read or write." what did you mean ?
