20 years agoPerformance Issues
I am in the process of debugging a custom Nios II system. I have implemented a NIOS II/f CPU with and EPCS controller. I have created a custom component to access a SRAM in which my firmware is runni...
20 years agoThe 150ns of time between reads to your peripheral could be for a lot of reasons depending on the implementation of your custom user logic and the amount of processing you are doing between reads. Maybe you could provide a little more info on what you are trying to do.
If you really need to do high speed transfers, you should consider using the DMA controller.
