21 years agoPerformance Counter
I want to measure a time count taken for a section of a code. But the output i'm getting is always zero. I'm viewing my output through IDE output console.
I have patched my code and the output i got. Note: Using Quarus II 4.2 SP1 Can anyone help me in this regard. Thanks, Sanchu.C # #########################CODE##################### # include <stdio.h># include "altera_avalon_performance_counter.h"# include "system.h" void* perfbase = 0x00100800; # define COMPUTE_FUNCTION_SECTION 1 void compute() { int counter,sum; sum=0; PERF_BEGIN (perfbase, COMPUTE_FUNCTION_SECTION); for(counter=0;counter<100;counter++) sum=sum+counter; PERF_END (perfbase, COMPUTE_FUNCTION_SECTION); printf("\n Sum = %d \n",sum); } int main() { printf("Hello from Nios II!\n"); PERF_RESET (perfbase); PERF_START_MEASURING (perfbase); compute(); PERF_STOP_MEASURING (perfbase); unsigned int section_time = 1; section_time = perf_get_section_time (perfbase,COMPUTE_FUNCTION_SECTION); printf ("section_time: %d\n",section_time); perf_print_formatted_report(perfbase, ALT_CPU_FREQ,1,"compute"); return 0; } # ##################OUTPUT VIEW THROUGH IDE CONSOLE##################### Hello from Nios II! Sum = 4950 section_time: 0 --Performance Counter Report-- Total Time: 0 seconds (0 clock-cycles) +---------------+-----+-----------+---------------+-----------+ | Section | % | Time (sec)| Time (clocks)|Occurrences| +---------------+-----+-----------+---------------+-----------+ |compute | NaN| 0.00000| 0| 0| +---------------+-----+-----------+---------------+-----------+3 Replies
Found a workaround for this problem:
It seems to work fine if I take the Verilog project from Standard folder under \kits\nios2\examples\verilog\niosII_stratix_1s10\standard and add performance counter to it. If I take Vhdl project from Standard folder under \kits\nios2\examples\vhdl\niosII_stratix_1s10\standard then, it is not working fine. - Altera_Forum
--- Quote Start --- originally posted by sanchu@Mar 15 2005, 06:23 AM found a workaround for this problem:it seems to work fine if i take the verilog project from standard folder under \kits\nios2\examples\verilog\niosii_stratix_1s10\standard and add performance counter to it.
if i take vhdl project from standard folder under \kits\nios2\examples\vhdl\niosii_stratix_1s10\standard then, it is not working fine. --- Quote End --- I'm having the same problem... does anyone got it running using VHDL? Paolo
yes for me it seem to work in vhdl,
i'm using the kit cyclone(EP1C20) from altera, with nios2.1 quartus 4.2 sp1.
