20 years agoPERFORMANCE_COUNTER_BASE
Hi, I am following performance counter part (tutorial) ' an391 '
And I have a problem. When I click 'build' from NiosII IDE, I get below message : //// **** Incremental build of configuration Release for project performance_project **** make -s all Compiling checksum_test.c... Compiling high_res_timestamp_performance_project.c... ../high_res_timestamp_performance_project.c: In function `main': ../high_res_timestamp_performance_project.c:132: error: `PERFORMANCE_COUNTER_BASE' undeclared (first use in this function) ../high_res_timestamp_performance_project.c:132: error: (Each undeclared identifier is reported only once ../high_res_timestamp_performance_project.c:132: error: for each function it appears in.) make: *** [obj/high_res_timestamp_performance_project.o] Error 1 Build completed //// By looking at the error lines, I can guess that `PERFORMANCE_COUNTER_BASE' undeclared. So I looked up three files and I couldn't find the above anywhere. So I declare it as # define PERFORMANCE_COUNTER_BASE 0 because the line says /* * Reset (initialize to zero) all section counters and the global * counter of the performance_counter peripheral. */ PERF_RESET (PERFORMANCE_COUNTER_BASE); <== error line I could compile it but when I run it as hardware, It give me below lines and hanging there forever. // nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Hello from Nios II Performance Checksum Test! // I've tried to place the above # define PERFORMANCE_COUNTER_BASE 0 at 'high_res_timestamp_performance_project.c' first time. and at first and 'checksum_test.c' second time. Both compiled but result are same. Just hanging and doesn't give me back any result. What could be a problem? I've followed the tutorial. And it doesn't say anything about this. Am I missing something? I am using QuartusII v5.0 with UP3 board (Cyclone EP1C6Q240C) Someone says the tutorial is for v5.1. Is that a problem? I think it's not a major problem. It seems to be simple problem... Anybody know this problem, please help me. YOng.2 Replies
I could be going out on a limb here, but I'd bet that your hardware (SoPC Builder design) doesn't have a performance counter....right???
Cheers, - slacker - Altera_Forum
and it must be called "performance_counter" ... check your system.h in the system library...
Paolo
