21 years agoPCMCIA interface in Nios II
I am Ana Belen Lopez and I am working with the processor Nios II. I need to install some drivers and for that, I need to configure the PCMCIA option in the kernel. The problem is the kernel doesn't have that option. Does anyone of you know where I can find the suitable patch or drivers to install it in the kernel? I would be very pleased if some could help me. Thanks, Ana.4 Replies
Hi Ana,
> the kernel doesn't have that option. The option is just a little hard to find, but it's there: Select "Bus Options" at the top-level of the kernel configuration and enable "Support for hot-pluggable device". Then you will see "PCMCIA/Cardbus support". Regards, --Scott - Altera_Forum
Hi Scott,
thank you very much. Ana. - Altera_Forum
HI :
where to find the "Bus Options" ? I didn't find it ?! thanks - Altera_Forum
Hi aihuazou,
> where to find the "Bus Options" ? I didn't find it ?! > > Select "Bus Options" at the top-level of the kernel configuration Regards, --Scott
