13 years agoPCIe Root Port Configuration using NIOS via Avalon-MM Interface on Cyclone 5 Board
Does anyone have refence code or steps needed for configuring PCIe (PCI Express) as Root Port (Root Complex) via the NIOS-II processor on a Cyclone 5 board using the Avalon-MM interface ? I'm...
13 years agoHave you found any reference?
Thanks. --- Quote Start --- Does anyone have refence code or steps needed for configuring PCIe (PCI Express) as Root Port (Root Complex) via the NIOS-II processor on a Cyclone 5 board using the Avalon-MM interface ? I'm trying to understand the basic steps needed to configure the PCIe interface and leverage a reference example for our application. Any specifics regarding root port and end port registers and there values would also be helpful. Once again, I'm trying to configure the PCIe interface using the NIOS-II/f proccessor via the Avalon-MM interface and expecting everything to be memory mapped addressed and would like feedback on this as well. Thanks --- Quote End ---
