13 years agoPCIe Memory Write/Read abnormal behavior
We have a PCIe core that is configured as a rootport. It is connected
to a switch which has a single device on the downstream side. We enumurated the PCIe busses successfuly and moved on to memory IO mapping. the device has 1MB memory and we configured its base address to 0x40000000. We set The command register to 6, enabling memory space and bus master. The downstream bridge, connected to the device, memory base/limit register is set to 0x40004000, so as the upstream bridge connected to the root-port. All have memory space and bus master enabled. Now we are facing 2 problems: 1. We can write to/read from even addresses of double-words (0x00, 0x08, 0x10, etc.), but when we read from odd DW addresses (e.g. 0x04, 0x0c, etc.) we receive only the header of the TLP packet (indicating 1 DW, 4 bytes) but no data is available on the FIFO. 2. When we write memory with multiple words payload we read back old data, i.e. the memory write did not take place at all. PCIeFnWriteMemory32: requester_id 0000 (0,0,0), tag 1F, target_addr 40000100 , data 123ABCDE TX Data = 0x40000001 TX Data = 0x00001f0f TX Data = 0x40000100 TX Data = 0x00000000 TX Data = 0x123abcde TX Data = 0x00000000 PCIeFnWriteMemory32: requester_id 0000 (0,0,0), tag 1F, target_addr 40000104 , data 12ABCDEF TX Data = 0x40000001 TX Data = 0x00001f0f TX Data = 0x40000104 TX Data = 0x00000000 TX Data = 0x12abcdef TX Data = 0x00000000 PCIeFnReadMemory32: requester_id 0000 (0,0,0), tag 1F, target_addr 40000100 TX Data = 0x00000001 TX Data = 0x00001f0f TX Data = 0x40000100 TX Data = 0x00000000 RX Data = 0x4a000001 RX Data = 0x09000004 RX Data = 0x00001f00 RX Data = 0x00000000 RX Data = 0x123abcde RX Data = 0x123abcde completion status 0, Successful Completion (SC) PCIeFnReadMemory32: requester_id 0000 (0,0,0), tag 20, target_addr 40000104 TX Data = 0x00000001 TX Data = 0x0000200f TX Data = 0x40000104 TX Data = 0x00000000 RX Data = 0x4a000001 RX Data = 0x09000004 RX Data = 0x00002004 RX Data = 0x00000000 RX FIFO is empty !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! completion status 0, Successful Completion (SC) Has anyone encounter such behavior? Any ideas? S.1 Reply
Found the problem ! The TX packet has two extra DW of 0x00000000 which must not be there. This violates the memory write spec. for 32bit access. So, instead
of: TX Data = 0x40000001 TX Data = 0x00001f0f TX Data = 0x40000100 TX Data = 0x00000000 TX Data = 0x123abcde TX Data = 0x00000000 it should be: TX Data = 0x40000001 TX Data = 0x00001f0f TX Data = 0x40000100 TX Data = 0x123abcde The SW guy has a red face now... S. (HW guy)
