13 years agoPCIe "Enumeration" SW on NIOS II ?
Hi All, Does anyone know where I can get PCIe Enumeration program (written in 'C') to run on NIOS II ? I have the Stratix IV dev. board, configured as RooPort, plugged into a chassis with a ...
13 years agoDear Shvitzer,
I am facing the same problem. The solution can be found in u-boot? Or you had to write the entire code? Regards, Michele. --- Quote Start --- Thanks Dave. I will do that. Cheers, Shvitzer --- Quote End ---
