20 years agoPCI in uClinux
Does suported PCI in uClinux for NIOS II with Altera PCI Compiler 4.0 pci_mt_32 megafuntion ? Anywho uses this options ? I can't compile kernel with PCI support... http://forum.nio...
20 years ago --- Quote Start --- originally posted by mabcom@Sep 29 2006, 01:45 AM hi hippo,
how fast is the pci implementation?
does it works with dma? i think it's a little bit slowly when i test the pci performance with giga-ethernet.
i think the linux tcp-ip-stack doesn't use the pci-memory access.
can we solve it quickly?
thanx
marco
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18494)
--- quote end ---
--- Quote End --- Hi MadCom, would it be possible for you to create on "how-to" on Nios Wiki, explaining what you did (hardware, Ip cores used... and of course uClinux driver). I think it would help a lot of people. Thanx. Regards.
