20 years agoPCI in uClinux
Does suported PCI in uClinux for NIOS II with Altera PCI Compiler 4.0 pci_mt_32 megafuntion ? Anywho uses this options ? I can't compile kernel with PCI support... http://forum.nio...
20 years agoHi Hippo,
how fast is the PCI implementation? Does it works with DMA? I think it's a little bit slowly when i test the PCI Performance with Giga-Ethernet. I think the Linux TCP-IP-Stack doesn't use the PCI-Memory Access. Can we solve it quickly? Thanx Marco
