20 years agoPCI in uClinux
Does suported PCI in uClinux for NIOS II with Altera PCI Compiler 4.0 pci_mt_32 megafuntion ? Anywho uses this options ? I can't compile kernel with PCI support... http://forum.nio...
20 years agoHi Marco,
When I perpared the altpci driver, I had tried to simplify the address translation between pci space and avalon space. I decided to use the same address mapping for both spaces, so that I don't have to add another address tables in drivers. I checked your ptf and altpci.c . Please update in the pci core toolbench, page 4, avalon config. change the pci base address in the address translation table, row 0, pci config space, pci base 0, == avalon 0x06000000 uncached to nios2 0x86000000 row 1, pci mem space, pci base 0x86100000, == nios2 0x86100000 row 2, pci mem space, pci base 0x86200000, == nios2 0x86200000 .... row 7, pci io space, pci base 0x86700000, == nios2 0x86700000 Note, we need to uncache the access for nios2, by setting address bit 31 . Hope this will help. Hippo
