20 years agoPCI in uClinux
Does suported PCI in uClinux for NIOS II with Altera PCI Compiler 4.0 pci_mt_32 megafuntion ? Anywho uses this options ? I can't compile kernel with PCI support... http://forum.nio...
20 years agoHi Hippo,
The System PTF File you can find here (http://www.mabcom.de/std_2s60.ptf) The altpci.c-File you can find here (http://www.mabcom.de/altpci.c) I hope you can find anything http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif Thanx Marco --- Quote Start --- originally posted by hippo@Sep 26 2006, 11:24 PM hi marco,
there are no active devsel nor trdy.
so the e1000 is not responding to memory access.
the ad bus is floating, and the value is meaningless.
can you give your sopc ptf and altpci.c ?
i will check the translation table.
the pci clock might be ok, since you can access the config space.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18458)
--- quote end ---
--- Quote End ---
