20 years agoPCI in uClinux
Does suported PCI in uClinux for NIOS II with Altera PCI Compiler 4.0 pci_mt_32 megafuntion ? Anywho uses this options ? I can't compile kernel with PCI support... http://forum.nio...
20 years agoHi Hippo, Hi Bigboss
Thanx for your answers... i have now logged the PCI Bus DATA-READ (BE = 0x06h). Here is a plot from the SignalTap trace: trace-picture (http://www.mabcom.de/pci.jpg) Maybe something wrong? My Software gives a 0x32bfffff when read from Adress 0x200000. In the Signaltap you see another value. Why? Any ideas? What about the PCI clk? I have clocked the Signaltap Analyser with PCI_CLK. I generate a 33MHz CLK and give it to CLK_PCI_COMPILER input clk and also the same clock to the Hardware PCI_CLK_Pin. I have also added Phase-Shifting, but that doesn't work. I hope you can help me http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Bye Marco
