13 years agoPausing target processor: not responding.
when i try to run as NIOS II hardware, i am getting this error, Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying ...
13 years agoDid you modify the example in any way? Check epsecially the clock and reset input. The reset is active low so it must be high for the system to work. You can verify that the clock is running by using signaltap, either by monitoring the clock signal itself, or by using it as the clock in signaltap (it will say "waiting for clock" if the clock isn't toggling).
