20 years agoPausing target processor: not responding.
--------------------- Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paus...
20 years agoI've been having this same problem too. I get the error message:
Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x01 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused I can program my .sof to the board no problem, I can compile my C application too, but when i go to run the C code on the processor I get that error message. I can't even use the flash programmmer to program the flash memory either, I get an error along the same lines as the one above. If anybody has any ideas i'd greatly appreciate them.
