20 years agopartitioning CF card error
hi, hippo when I partition CF card in the last step by entering "w" at the main prompt. it showns below: "The partition table has been altered! Calling ioctl<> to re-read partition table. h...
20 years ago --- Quote Start --- originally posted by slacker@Jun 28 2006, 12:20 AM those look like typical linux warnings, except for the first bit. if you type fdisk <your dev> and then type "p", what does that show? if you were successful, you should see a listing of all partitions on your card. from this point, you should be able to format your partition(s) and get on with the flow.
good luck!
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16435)
--- quote end ---
--- Quote End --- thanks! when I fdisk CF card: "#fdisk /dev/hda hda:unknown partition table device contains neither a valaid DOS partition table, or Sun,SGI or OSF disklabel Building a new DOS disklabel. Changes will remain in memory only, until you decide to write them. After that, of coure, the previous content will not be recoverable. " can u help me? thanks!
