20 years agopartitioning CF card error
hi, hippo when I partition CF card in the last step by entering "w" at the main prompt. it showns below: "The partition table has been altered! Calling ioctl<> to re-read partition table. h...
20 years agoThose look like typical Linux warnings, except for the first bit. If you type fdisk <your dev> and then type "p", what does that show? If you were successful, you should see a listing of all partitions on your card. From this point, you should be able to format your partition(s) and get on with the flow.
Good luck! - slacker
