20 years agoParallel Flash Problems
I have searched tediously through the forums for any help on this, and have tried a lot of different things. I am using the same Flash chip as on the NIOS II Cyclone II Eval board on a custom d...
20 years ago --- Quote Start --- originally posted by liangyi@Feb 23 2006, 01:23 AM hi,
do you use pull up resistors with ce#, oe#, we#, rst# and use pull down resistor with byte#?
i think you should check schematics first to confirm nothing wrong and solder rightly.
regards,
liangyi
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12907)
--- quote end ---
--- Quote End --- Yes, they are all pulled up and down. I don't know how to post attachments, so I put the PDF of the schematic here: http://www.fps-tech.net/docs/flash.pdf (http://www.fps-tech.net/docs/flash.pdf)
