20 years agoParallel Flash Problems
I have searched tediously through the forums for any help on this, and have tried a lot of different things. I am using the same Flash chip as on the NIOS II Cyclone II Eval board on a custom d...
20 years agoHi,
Do you use pull up resistors with CE#, OE#, WE#, RST# and use pull down resistor with BYTE#? I think you should check schematics first to confirm nothing wrong and solder rightly. Regards, LiangYi
