20 years agoParallel Flash Problems
I have searched tediously through the forums for any help on this, and have tried a lot of different things. I am using the same Flash chip as on the NIOS II Cyclone II Eval board on a custom d...
20 years agoIf it is not logic problem, then it must be board wiring problem. Try some walking tests on the addr/data, with different set of data pattern. make sure you have proper control signal such as reset# etc.
