20 years agoParallel Flash Problems
I have searched tediously through the forums for any help on this, and have tried a lot of different things. I am using the same Flash chip as on the NIOS II Cyclone II Eval board on a custom d...
20 years agoFor current strength, I meant flash io pins. Lower current stength will lower slew, and lower noise.
Try running a read/write flash loop from dram, and hook up scope to check the addr/data/cmd waveform. Did you use uncached access?
