20 years agoParallel Flash Problems
I have searched tediously through the forums for any help on this, and have tried a lot of different things. I am using the same Flash chip as on the NIOS II Cyclone II Eval board on a custom d...
20 years ago --- Quote Start --- originally posted by hippo@Feb 22 2006, 08:35 PM you can try download a program into dram, and try out flash read write from dram. so that you can isolate if it is a jtag problem or others.
you can try to set io pin current stength to minimum. the jtag singal is weak. you should also try add series terminator / pull high to jtag signals.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12896)
--- quote end ---
--- Quote End --- Hey hippo; I don't see how setting the current strength to minimum will help JTAG? I can't set the signal strengths on the JTAG pins (I don't think). And I don't think JTAG is the problem since I Can download code and run from DRAM without problem, as well as use Signal Tap. Also, I have tried what you said, reading/writing Flash from DRAM, and similar errors happen; I can confirm that errors I see with SignalTap are the same errors detected in code. I have also replaced the chip, so it's not the chip... and the circuit is a duplicate of what is on the Cyclone II dev board (just for some more info)
