20 years agoParallel Flash Problems
I have searched tediously through the forums for any help on this, and have tried a lot of different things. I am using the same Flash chip as on the NIOS II Cyclone II Eval board on a custom d...
20 years ago --- Quote Start --- originally posted by jdhar@Feb 22 2006, 07:27 PM on a 16-bit device in x8 mode, the reading of address and address+1 should be the same value.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12894)
--- quote end ---
--- Quote End --- I do not use AM29LV128M, but I think, that's not correct, because in BYTE mode A0 should be connected to (D15-A-1) of the flash (see Texas_rev01_sch_production.pdf in ..\documents\nios_cycloneII_2c35 of nios 5.1 best regards
