20 years agoParallel Flash Problems
I have searched tediously through the forums for any help on this, and have tried a lot of different things. I am using the same Flash chip as on the NIOS II Cyclone II Eval board on a custom d...
20 years agoYou can try download a program into dram, and try out flash read write from dram. So that you can isolate if it is a jtag problem or others.
You can try to set io pin current stength to minimum. The jtag singal is weak. You should also try add series terminator / pull high to jtag signals.
