21 years agoOwn system with uCLinux 1.3
I got uCLinux 1.3 running on my ALTERA Stratix-10ES eva board. I now like to define my own NIOS-II system, but don't get it running. Unfortunately 1.3 distribution only contains a .sof & .ptf, but no complete project source. So I used "linux_1s10ES.ptf" as a basis for my own project. Essentially I took the "full_featured" standard example and changed the NIOS-II system therein, carefully obeying pin-assignments of CF ports. Now when booting my system it displays in the terminal .... forever What went wrong? Many thanks in advance for hints! regards Hans --- nios2-terminal: starting in terminal mode (Control-C exits) Linux version 2.6.9-uc0 (...) (gcc version 3.4.1 (Altera Nios II 1.1 b137))# 1 Sun Mar 6 14:40:38 2005 uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 128 (order: 7, 2048 bytes) Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) Memory available: 14396k/16384k RAM, 0k/0k ROM (1472k kernel code, 323k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) NET: Registered protocol family 16 Serial: JTAG UART driver $Revision: 1.3 $ ttyJ0 at MMIO 0x80920820 (irq = 2) is a jtag_uart RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize smc_probe: 50000 Khz Nios SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6) eth0: SMC91C11xFD(rev:1) at 0x80910300 IRQ:5 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:ed:0a:a5:06 smc_probe: 50000 Khz Nios Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2 ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx CF: ctl=1 /cygdrive/e/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/ke rnel/irq.c(55): default irq handler vec=6 [0x6] /cygdrive/e/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/ke rnel/irq.c(55): default irq handler vec=6 [0x6] : :3 Replies
If you don't have a compact flash component built in your core, you can disable the support of ATA/ATAPI/MFM/RLL in the kernel configuration. It can be found in kernel config->device drivers.
you can turn on version 1.4 of nios linux, it includes all the sources you want. Good work - Altera_Forum
1. Do you mean your own system is NOT Atera Stratix-10ES eva board ?
2. you can find the eva boards verilog sources from Nios2 install dir, eg altera/kits/nios2/examples/verilog/niosII_stratix_1s10_ES/standard 3. when you build kernel, start with minimal config.
