16 years agoown component and ADDRESS_MAP
According 'Hardware Tcl Command Reference' guide, I would like to use the 'ADDRESS_MAP' command so as to assign a string describing the address map to a parameter. My component is called "MyComponent". In "MyComponent_hw.tcl", I add: add_parameter my_map_param STRING set_parameter_property my_map_param SYSTEM_INFO {ADDRESS_MAP MyComponent}. ... because I would like to have all address map describing my SOPC system into the parameter called 'my_map_param' When I open SOPC builder, this latest blocks (no more edition, I can't do anything ...). How can I use correctly the 'ADDRESS_MAP' command? Many thanks.No RepliesBe the first to reply
