15 years agoow to define an uncached linker region
Can anyone tell me how to define a region in the linker to be uncached? An example - I have a block ram I am using for SGDMA descriptor tables that I need to define as uncached... Thanks - Chris
15 years agoIf you haven't enabled the MMU, then a31 acts as a 'cache bypass' when accessing Avalon MM addresses rather than as an address line. You may need to ensure the bit is masked if other Avalon masters use the addresses.
Another way is to use the ldio/stio instructions (which is what the IORD macros do). The third way is to remove the data cache entirely and put all your data (including the rodata sections) into tightly coupled data areas. This is only really an option for small systems though.
