21 years agoOverlapping tightly coupled memories?
Hi all, I'm designing a multiprocessor system. In that system, there is a cpu with 1 instruction (i1) and 2 data (s1 and s2) tyghtly coupled masters. These masters are connected to an ...
21 years agoYou can safely ignore these messages if you are happy with your frequency.
The messages are just telling you that the CPU isn't generating the optimal address decoding logic. If you want to do the optimal, just change your address map to avoid the overlap. Put the tightly coupled memories at the high or low end of memory.
