16 years agoOutput files to host
I want my NisoII Processor send real-time information to the host, and write these information into a file.
This is my C code. FIFE* fp=fopen("/mnt/host/h.txt"); if(fp==NULL){ printf("Error in opening file\n"); return -1; } fprintf(fp,"Hello world\n"); fclose(fp); return 0; This code will work well in debug mode step by step, and it will generate a file named h.txt in my host PC machine. But It will not work in release mode. Can anyone help me? Thanks2 Replies
You need a data channel to the host.
In debug mode the jtag interface can be used. For releases you need to add some other interface between the fpga and whatever host you are using. - Altera_Forum
--- Quote Start --- You need a data channel to the host. In debug mode the jtag interface can be used. For releases you need to add some other interface between the fpga and whatever host you are using. --- Quote End --- Can you describe detail? what kind of interface need add? Is there any interface already existed in the SOPC Build? Thanks
