21 years agoOut of Memory
I've been fighting with my flash on a custom board for the last 2 days. I could not mount mtdblock0, turned out to be a problem with busybox. I got over that hurdle only to find a memory alloca...
21 years agoYour problem is there is not enough available paged memory (only 128KB) to run many programs. You are going to have to try and reduce your kernel footprint. Start by disabling the following kernel config options
General Setup > Configure standard kernel features (for small systems) > Load all symbols for debugging/kksymoops Loadable module support > Enable loadable module support Device Drivers > Character Devices > Unix98 PTY support Device Drivers > Charater Devices > Legacy (BSD) PTY support File system > DOS/FAT/NT > VFAT (Windows-95) fs support File system > Network filesystems > NFS filesystem support Kernel Hacking > Full Symbolic/Source Debugging support If that does not give you enough space you could look at reducing the size of the ramfs.img size to create a smaller ramdisk.
