15 years agoopenswan on uClinux and try to run it on an nommu system
Hi..
Is there any one trying to build openswan from uClinux's distribution (either 20090730 or 20100621)? At first, it won't compiled correctly.. after fixing some compiler flags in Makefile under uClinux-dist/openswan and fix romfsinst.sh in Makefile under uClinux/user/openswan, I can get it compiled successfully. However, when running zImage on our nommu system.. it's not working properly.. I guess it is very likely this issue links to 'fork' (since openswan seems relying on fork). So my question is.. Has anybody ever tried to run IPSEC with openswan successfully on nommu system... If you have, please share your experience.. Thanks. Leon.No RepliesBe the first to reply
