19 years agoOpencores (IGOR) problem
I am trying to make a linux kernel (2.6.x) on Altera NIOSII, everything works correctly (I can create an image with default options) but... but when I check field Opencores (IGOR) Emac Support in Kernel Configuration (I tried it with Ethernet 10 or 100Mbit enabled and later disabled) and "make" I see the following error: make -C tools/ucfront make[1]: Entering directory `/home/mk/mgr/uClinux-dist/tools/ucfront' make[1]: Nothing to be done for `all'. make[1]: Leaving directory `/home/mk/mgr/uClinux-dist/tools/ucfront' ln -sf /home/mk/mgr/uClinux-dist/tools/ucfront/ucfront tools/ucfront-gcc ln -sf /home/mk/mgr/uClinux-dist/tools/ucfront/ucfront tools/ucfront-g++ ln -sf /home/mk/mgr/uClinux-dist/tools/ucfront/ucfront-ld tools/ucfront-ld make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -j1 -C linux-2.6.x zImage || exit 1 no emulation specific options. make[1]: Entering directory `/home/mk/mgr/uClinux-dist/linux-2.6.x' no emulation specific options. scripts/kconfig/conf -s arch/nios2nommu/Kconfig block/Kconfig:36:warning: 'select' used by config symbol 'BLK_DEV_IO_TRACE' refer to undefined symbol 'DEBUG_FS' make[1]: Leaving directory `/home/mk/mgr/uClinux-dist/linux-2.6.x' no emulation specific options. make[1]: Entering directory `/home/mk/mgr/uClinux-dist/linux-2.6.x' CHK include/nios2_system.h perl -I/home/mk/mgr/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts /home/mk/mgr/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl nios2 sdram flash < /home/mk/mgr/quart/eth_vip_cyc.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo ' UPD include/nios2_system.h'; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi CHK include/linux/version.h CHK include/linux/utsrelease.h CHK include/linux/compile.h GEN usr/initramfs_data.cpio.gz AS usr/initramfs_data.o LD usr/built-in.o CC arch/nios2nommu/kernel/setup.o arch/nios2nommu/kernel/setup.c: In function `setup_arch': arch/nios2nommu/kernel/setup.c:325: warning: implicit declaration of function `paging_init' LD arch/nios2nommu/kernel/built-in.o CC drivers/net/Space.o drivers/net/Space.c:204: error: `oeth_init' undeclared here (not in a function) drivers/net/Space.c:204: error: initializer element is not constant drivers/net/Space.c:204: error: (near initialization for `isa_probes[0].probe') drivers/net/Space.c:204: error: initializer element is not constant drivers/net/Space.c:204: error: (near initialization for `isa_probes[0]') drivers/net/Space.c:260: error: initializer element is not constant drivers/net/Space.c:260: error: (near initialization for `isa_probes[1]') make[3]: *** [drivers/net/Space.o] Error 1 make[2]: *** [drivers/net] Error 2 make[1]: *** [drivers] Error 2 make[1]: Leaving directory `/home/mk/mgr/uClinux-dist/linux-2.6.x' make: *** [linux] Error 1 At line 204 in file Space.c I can see:# if defined(CONFIG_OPEN_ETH) {oeth_init, 0},# endif What do I do wrong ? I am a beginner so everything is new for me... Thank you for your response in advance, With Regards, Koza2 Replies
Please update Space.c,
Please attach your ptf in the wiki, so that I can test the build with open eth in the future. http://nioswiki.jot.com/wikihome/operatingsystems/ethernet (http://nioswiki.jot.com/wikihome/operatingsystems/ethernet)Index: Space.c =================================================================== --- Space.c (revision 31) +++ Space.c (revision 32) @@ -73,6 +73,8 @@ extern struct net_device *SK_init(int unit); extern struct net_device *seeq8005_probe(int unit); extern struct net_device *smc_init(int unit); +extern struct net_device *oeth_init(int unit); +extern struct net_device *mtip1000_init(int unit); extern struct net_device *dm9ks_probe(int unit); extern struct net_device *atarilance_probe(int unit); extern struct net_device *sun3lance_probe(int unit); - Altera_Forum
TO_BE_DONE
