20 years agoOpencores I2C Core and uClinux Driver
I have added an Altera Avalon SOPC Builder I2C Master component based on the Opencores I2C Host. http://via.dynalias.org/svn/fpga/cores/i2c_master/trunk/ (http://via.dynalias.org/svn/fpga/core...
19 years agoHippo,
Tried that, still have problems: CC drivers/i2c/algos/i2c-algo-oc.o
drivers/i2c/algos/i2c-algo-oc.c:484: error: redefinition of 'i2c_debug'
drivers/i2c/algos/i2c-algo-oc.c:66: error: previous definition of 'i2c_debug' was here
drivers/i2c/algos/i2c-algo-oc.c:500: error: redefinition of 'i2c_start'
drivers/i2c/algos/i2c-algo-oc.c:82: error: previous definition of 'i2c_start' was here
drivers/i2c/algos/i2c-algo-oc.c:506: error: redefinition of 'i2c_repstart'
drivers/i2c/algos/i2c-algo-oc.c:88: error: previous definition of 'i2c_repstart' was here
drivers/i2c/algos/i2c-algo-oc.c:512: error: redefinition of 'i2c_stop'
drivers/i2c/algos/i2c-algo-oc.c:94: error: previous definition of 'i2c_stop' was here
drivers/i2c/algos/i2c-algo-oc.c:518: error: redefinition of 'wait_for_bb'
drivers/i2c/algos/i2c-algo-oc.c:100: error: previous definition of 'wait_for_bb' was here
drivers/i2c/algos/i2c-algo-oc.c:542: error: redefinition of 'try_address'
drivers/i2c/algos/i2c-algo-oc.c:124: error: previous definition of 'try_address' was here
drivers/i2c/algos/i2c-algo-oc.c:564: error: redefinition of 'oc_sendbytes'
drivers/i2c/algos/i2c-algo-oc.c:146: error: previous definition of 'oc_sendbytes' was here
drivers/i2c/algos/i2c-algo-oc.c:602: error: redefinition of 'oc_readbytes'
drivers/i2c/algos/i2c-algo-oc.c:184: error: previous definition of 'oc_readbytes' was here
drivers/i2c/algos/i2c-algo-oc.c:641: error: redefinition of 'oc_doAddress'
drivers/i2c/algos/i2c-algo-oc.c:223: error: previous definition of 'oc_doAddress' was here
drivers/i2c/algos/i2c-algo-oc.c:711: error: redefinition of 'oc_xfer'
drivers/i2c/algos/i2c-algo-oc.c:293: error: previous definition of 'oc_xfer' was here
drivers/i2c/algos/i2c-algo-oc.c:785: error: redefinition of 'oc_func'
drivers/i2c/algos/i2c-algo-oc.c:367: error: previous definition of 'oc_func' was here
drivers/i2c/algos/i2c-algo-oc.c:792: error: redefinition of 'oc_algo'
drivers/i2c/algos/i2c-algo-oc.c:374: error: previous definition of 'oc_algo' was here
drivers/i2c/algos/i2c-algo-oc.c:793: error: unknown field `name' specified in initializer
drivers/i2c/algos/i2c-algo-oc.c:793: warning: initialization from incompatible pointer type
drivers/i2c/algos/i2c-algo-oc.c:794: error: unknown field `id' specified in initializer
drivers/i2c/algos/i2c-algo-oc.c:794: error: `I2C_ALGO_OC' undeclared here (not in a function)
drivers/i2c/algos/i2c-algo-oc.c:794: error: initializer element is not constant
drivers/i2c/algos/i2c-algo-oc.c:794: error: (near initialization for `oc_algo.smbus_xfer')
drivers/i2c/algos/i2c-algo-oc.c:803: error: redefinition of 'i2c_oc_add_bus'
drivers/i2c/algos/i2c-algo-oc.c:383: error: previous definition of 'i2c_oc_add_bus' was here
drivers/i2c/algos/i2c-algo-oc.c: In function `i2c_oc_add_bus':
drivers/i2c/algos/i2c-algo-oc.c:810: error: structure has no member named `id'
drivers/i2c/algos/i2c-algo-oc.c:804: warning: unused variable `oc_adap'
drivers/i2c/algos/i2c-algo-oc.c: At top level:
drivers/i2c/algos/i2c-algo-oc.c:822: error: redefinition of 'i2c_oc_del_bus'
drivers/i2c/algos/i2c-algo-oc.c:399: error: previous definition of 'i2c_oc_del_bus' was here
drivers/i2c/algos/i2c-algo-oc.c:827: error: redefinition of 'i2c_algo_oc_init'
drivers/i2c/algos/i2c-algo-oc.c:404: error: previous definition of 'i2c_algo_oc_init' was here
drivers/i2c/algos/i2c-algo-oc.c:834: error: redefinition of 'i2c_algo_oc_exit'
drivers/i2c/algos/i2c-algo-oc.c:411: error: previous definition of 'i2c_algo_oc_exit' was here
drivers/i2c/algos/i2c-algo-oc.c:838: error: redefinition of '__kstrtab_i2c_oc_add_bus'
drivers/i2c/algos/i2c-algo-oc.c:415: error: previous definition of '__kstrtab_i2c_oc_add_bus' was here
drivers/i2c/algos/i2c-algo-oc.c:838: error: redefinition of '__ksymtab_i2c_oc_add_bus'
drivers/i2c/algos/i2c-algo-oc.c:415: error: previous definition of '__ksymtab_i2c_oc_add_bus' was here
drivers/i2c/algos/i2c-algo-oc.c:839: error: redefinition of '__kstrtab_i2c_oc_del_bus'
drivers/i2c/algos/i2c-algo-oc.c:416: error: previous definition of '__kstrtab_i2c_oc_del_bus' was here
drivers/i2c/algos/i2c-algo-oc.c:839: error: redefinition of '__ksymtab_i2c_oc_del_bus'
drivers/i2c/algos/i2c-algo-oc.c:416: error: previous definition of '__ksymtab_i2c_oc_del_bus' was here
drivers/i2c/algos/i2c-algo-oc.c:841: error: redefinition of '__initcall_i2c_algo_oc_init'
drivers/i2c/algos/i2c-algo-oc.c:418: error: previous definition of '__initcall_i2c_algo_oc_init' was here
drivers/i2c/algos/i2c-algo-oc.c:842: error: redefinition of '__exitcall_i2c_algo_oc_exit'
drivers/i2c/algos/i2c-algo-oc.c:419: error: previous definition of '__exitcall_i2c_algo_oc_exit' was here
make: *** Error 1
make: *** Error 2
make: *** Error 2
make: *** Error 2
make: Leaving directory `/home/uclinux/uClinux-dist/linux-2.6.x'
make: *** Error 1
uclinux@colinux:~/uClinux-dist$
