20 years agoOpencores I2C Core and uClinux Driver
I have added an Altera Avalon SOPC Builder I2C Master component based on the Opencores I2C Host. http://via.dynalias.org/svn/fpga/cores/i2c_master/trunk/ (http://via.dynalias.org/svn/fpga/core...
19 years agoHippo,
Did all that, and still get the followingmake: Entering directory `/home/uclinux/uClinux-dist/linux-2.6.x'
CHK include/nios2_system.h
perl -I/home/uclinux/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts /home/uclinux/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu ddr_sdram ext_flash < /windows/downloaded/std_2C35.ptf > include/nios2_system.h.tmp; if && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo ' UPD include/nios2_system.h'; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
CHK include/linux/version.h
SPLIT include/linux/autoconf.h -> include/config/*
CHK include/linux/compile.h
CC drivers/i2c/i2c-core.o
CC drivers/i2c/i2c-dev.o
CC drivers/i2c/algos/i2c-algo-bit.o
CC drivers/i2c/algos/i2c-algo-oc.o
drivers/i2c/algos/i2c-algo-oc.c:51: error: syntax error before string constant
drivers/i2c/algos/i2c-algo-oc.c:51: warning: type defaults to `int' in declaration of `MODULE_PARM'
drivers/i2c/algos/i2c-algo-oc.c:51: warning: function declaration isn't a prototype
drivers/i2c/algos/i2c-algo-oc.c:51: warning: data definition has no type or storage class
drivers/i2c/algos/i2c-algo-oc.c:374: error: unknown field `name' specified in initializer
drivers/i2c/algos/i2c-algo-oc.c:374: warning: initialization from incompatible pointer type
drivers/i2c/algos/i2c-algo-oc.c:375: error: unknown field `id' specified in initializer
drivers/i2c/algos/i2c-algo-oc.c:375: error: `I2C_ALGO_OC' undeclared here (not in a function)
drivers/i2c/algos/i2c-algo-oc.c:375: error: initializer element is not constant
drivers/i2c/algos/i2c-algo-oc.c:375: error: (near initialization for `oc_algo.smbus_xfer')
drivers/i2c/algos/i2c-algo-oc.c: In function `i2c_oc_add_bus':
drivers/i2c/algos/i2c-algo-oc.c:391: error: structure has no member named `id'
drivers/i2c/algos/i2c-algo-oc.c:385: warning: unused variable `oc_adap'
make: *** Error 1
make: *** Error 2
make: *** Error 2
make: *** Error 2
make: Leaving directory `/home/uclinux/uClinux-dist/linux-2.6.x'
make: *** Error 1
uclinux@colinux:~/uClinux-dist$
