20 years ago
opencores EMAC
Can anyone help me correctly wire up the avalon signals to the open cores EMAC 10/100. I am aware that the wishbone and avalon bridges have a simular set of signals with different names; however, there isn't a complete 1 to 1 mapping. I believe that I have made the neccessary changes in the verilog file eth_defines.v to allow the project to be built on a altera fpga. I have also created the required memory for modules and have verified that the design does compile under quartus.
thanks
    Hi, I have the same problem.
    If you have find the solution, let me know.
    Freechip
    I am also trying to modify the Wishbone Ethernet IP core to be implemented in Quartus and SOPC Builder. I have run the verilog codes in the "rtl\verilog" folder in Quartus and it runs without any errors and warnings.
    I was advised before this to modify the eth_wishbone.v file by dropping the wishbone bus interface and adding the avalon bus interface.
    While I was studying this file, I saw that some part of it did support Avalon, such as the code:
    `ifdef ETH_AVALON_BUS
    endif
    And also I tried to identify the various Wishbone signals for Wishbone common, Wishbone slave and Wishbone master, and finding the corresponding compatible signals in Avalon such as chipselect, waitrequest, byteenable, ....etc. While I did take out some seems unused signals by Avalon such as those error signals : err_<>_ and m_wb_cti_o and m_wb_bte_o. And i also dropped off those with
    `ifdef ETH_WISHBONE_B3
    endif
    I really not sure whether I am doing the correct way.
    Then once the file is compiled without syntax errors(though, ..) , I tried to create a new component in SOPC Builder using Component Editors. Once the signals are loaded in the Signals Tab, I tried to set the signal types such as whether it is "avalon_slave" or " avalon_master" and whether it is a " chipselect" ,"begintransfer", "byteenable"...etc.
    But there are some signals, I don&#39;t know whether it belongs to " avalon_slave " or "avalon_master" such as those going to and coming from PHY chip as follows:
    (So I just see whether these signals is coming from PHY into a slave , so I put "avalon_slave" , "input" as "export" , or "global signals" as "export")
    input InvalidSymbol; // Invalid symbol was received during reception in
    //100 Mbps mode
    input LatchedCrcError; // CRC error
    input RxLateCollision; // Late collision occured while receiving frame
    input ShortFrame; // Frame shorter then the minimum size (r_MinFL) was received while small packets are enabled (r_RecSmall)
    input DribbleNibble; // Extra nibble received
    input ReceivedPacketTooBig;// Received packet is bigger than r_MaxFL
    input [15:0] RxLength; // Length of the incoming frame
    input LoadRxStatus; // Rx status was loaded
    input ReceivedPacketGood;// Received packet&#39;s length and CRC are good
    input AddressMiss; // When a packet is received AddressMiss status is written to the Rx BD
    input r_RxFlow;
    input r_PassAll;
    input ReceivedPauseFrm;
    // Tx Status signals
    input [3:0] RetryCntLatched; // Latched Retry Counter
    input RetryLimit; // Retry limit reached (Retry Max value + 1 attempts
    //were made)
    input LateCollLatched; // Late collision occured
    input DeferLatched; // Defer indication (Frame was defered before
    //sucessfully sent)
    output RstDeferLatched;
    input CarrierSenseLost; // Carrier Sense was lost during the frame
    //transmission
    // Tx
    input MTxClk; // Transmit clock (from PHY)
    input TxUsedData; // Transmit packet used data
    input TxRetry; // Transmit packet retry
    input TxAbort; // Transmit packet abort
    input TxDone; // Transmission ended
    output TxStartFrm; // Transmit packet start frame
    output TxEndFrm; // Transmit packet end frame
    output [7:0] TxData; // Transmit packet data byte
    output TxUnderRun; // Transmit packet under-run
    output PerPacketCrcEn; // Per packet crc enable
    output PerPacketPad; // Per packet pading
    // Rx
    input MRxClk; // Receive clock (from PHY)
    input [7:0] RxData; // Received data byte (from PHY)
    input RxValid; //
    input RxStartFrm; //
    input RxEndFrm; //
    input RxAbort; // This signal is set when address doesn&#39;t match.
    output RxStatusWriteLatched_sync2;
    //Register
    input r_TxEn; // Transmit enable
    input r_RxEn; // Receive enable
    input [7:0] r_TxBDNum; // Transmit buffer descriptor number
    // Interrupts
    output TxB_IRQ;
    output TxE_IRQ;
    output RxB_IRQ;
    output RxE_IRQ;
    output Busy_IRQ;
    // Bist
    `ifdef ETH_BIST
    input mbist_si_i; // bist scan serial in
    output mbist_so_o; // bist scan serial out
    input [`ETH_MBIST_CTRL_WIDTH - 1:0] mbist_ctrl_i; // bist chain shift control
    `endif
    At first, I assign the wb_stb to avalon "chipselect" , and wb_cyc to avalon "begintransfer", and wb_sel to avalon "byteenable", after I have studied the Wishbone specs and Avalon specs, and assigned based on my understanding. But I came across a topic in this Forum, that Mr./Mrs. slava stated that " wb_stb" and "wb_cyc" can be tied together in the Verilog code file itself. So how to do or write the code of combining the wb_stb and wb_cyc to behave as avalon "chipselect".
    Also, there is also a suggestion posted on using avalon naming :
    avs_(avalon valid slave) and avm_(avalon valid master), so do I write these naming in the Verilog file, changing wishbone "m_wb_<signalname> " to "avm_<signalname>. How do these suggestions , come into play in my initial problem of implementing Ethernet IP core in Avalon SOPC?
    I not sure whether I am doing the correct way, since I am still a new comer in Verilog and also Ethernet IP, therefore I need someone, some of you, who could kindly enlighten me. I really need help desperately.
