20 years agoOpenCores 10/100 EMAC problems
Hi all, I want to use the OpenCores 10/100 Ethernet MAC core in a NIOS I (v3.2) design on the Microtronix uKit. I use the SOPC builder version of that core what is published by MaCo Engineering...
20 years ago...it's me again.
I figured out, that if a packet is lost the MAC reports a TX ERROR. I also increased the clock rate from 66MHz to 75MHz and the point where it becomes worse shifts from 300Btyes to 1100Bytes in ICMP packet length. So I agree that it could be a problem of a to slow running system clock. I will try to setup the system clock to 100MHz - maybe this will solve to problem. regards, Marco.
