13 years agoOne question about nios2_multiprocessor
tt_nios2_multiprocessor_tutorial provides an example design which builds a multiprocessor system containing three processors that all share a memory buffer.Using the Nios II Integrated Developmen...
13 years agoTo do that you need a full multi-cpu aware operating system and hardware that supports locked 'read modify write' bus operations for locks (ok, you can use dekker's algorythm, but it isn't ideal for normal locks).
I don't know about microC/OS, but the nios cpu doesn't have the required locked bus ops.
