15 years agoOnChip memory access with external logic
Hi, I'm trying to access on-chip memory (data and instruction) from external logic. I've generated system with two dual ports on-chip memories one for data and one for instruction, and connecte...
15 years agoThanks,
i want to expose the memory ports, not the avalon slave - this i've done. in order to benefit a full BW usage of the memory. now i am using an simple avalon master, which utilize only half (even less) BW. i've defined new component with avalon master and export its signal. i didn't find the way to do so with pipeline master (only as bridge). i will try Qsys, i used SOPC.
