21 years agoOnChip Memory - Addressing problem
I'm designing a double NiosII core system but I've the following problem. In the SOPC Builder, I add 2 cpu, 2 jtag_uart and 2 onchip_memory rom. "Cpu1" is a master of "jtag_uart1"...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- Are both of your CPUs and peripherals in the same SOPC Builder system?[/b] --- Quote End --- Yes, they are <div class='quotetop'>QUOTE </div> --- Quote Start --- ...per SOPC Builder system, you have an entire Avalon address space; no two peripherals can share that address space...[/b] --- Quote End --- Is it true even if each Cpu is the ONLY master of the onchip_memory? CPU1 CPU2
JTAG1 MEMORY1 JTAG2 MEMORY2
ONCHIP_MEMORY1: Base Address 0x00000000 Reset Adrress: 0x00000000 Exception Address: 0x00000020
ONCHIP_MEMORY2: Base Address 0x00000000 Reset Adrress: 0x00000000 Exception Address: 0x00000020
=> "cpu_1 and cpu_2: illegal reset address or exception address. All CPU reset or exception addresses must be unique" This case should not be a problem.... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif there aren't shared peripherals....each CPU targets a unique memory!?!? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif In addition, in "AN 184: Simultaneous Multi-Mastering with the Avalon Bus" (page 3) I've read: ...becasuse master and slave peripherals are connected with dedicated paths, multiple masters can be active at the same time and can simultaneously transfer data to theis slaves. this simoultaneous multi-master architecture offers great throughput performance advantages compared to a traditional, shared bus architecture. master peripherals do not have to wait to access a target slave peripheral, as long as another master does not access the same slave at the same time.... Please, help me... Bye, Matteo
